Need help with clutch and sprocket
Fallenleopard
N.S.W Australia
I have a motorbike wheel and the project i am building i will be using a 41 or 35 pitch clutch but i need a rear sprocket to fit my motorbike wheel which is not really going to work does anyone have any advice?
I had the same problem with my minibike build. All my clutch and jackshaft sprockets were 35, and the pit bike frame sprocket was something else. I tried to get a plate sprocket that was 35 and had the tooth count that I wanted, but I couldn't. I eventually had to buy a sprocket that had a boss on it, and then had someone machine it off, cut the center hole larger, and drill the bolt holes for me.
This is a before and after
