does anyone have the clone engine from harbor freight? well i recently bought it for my go kart and im confused with where the throttle cable goes and how to secure it. if possible can you guys post up some pics of what you guys did to your harbor freight clone engine, and give me a list of parts that i need to connect it? thank you for your help
This is how I did it. Only works with stock filter and gas tank removed. You have to take the starter cover off and drill holes for the bolts to go thru. Use big washer on both sides of the starter for the metal is thin and will flex some with just the bolts and small washers.
BUT
This page may help you.
http://www.affordablegokarts.com/throttle-linkage.php
You can make that rod pretty easy. Just need to figure out how long. The set up on the bottom is what I used.
I had to buy the cable holder and the cable stop. about $5 at Ace Hardware.
Remember that the clone throttle has to push open. So you need a pivit point it making custom setup. A normal throttle cable wants to pull open.
That metal tab coming off the starter cover in the last pic holds the choke on. The last pic also shows my stock clone air filter hack sawed up to make a DIY air cleaner manafold.
