Troubled1
Need help choosing a clutch for a go kart im trying to build for my sons, I'm learning as I go so any help is appreciated. It came with a belt drive setup. The size of the drive wheel is 9" to 9 1/4" if that helps, (im not sure if thats the right terminology
Do I need to order a CC Pull'y, does the size of the pull'y effect performance as with sprockets / gear ratios. Do I have to order a Pull'y clutch or would there be enough tension to keep the belt on a CC without lips to keep the belt from slipping off. For instance a standard clutch with sprocket.
I found this 3/4" Clutch on BMICarts http://www.bmikarts.com/Pulley-Clutch-with-34-Bore_p_2986.html
Would this be a suitable clutch for Predator 212 engine, 6x12 street tires, and aprox 65lb thru 200 lbs riders.
And is this the old clutch??? on the inside of the wheel??
Thanks so much for your help. You can see other pics here http://www.diygokarts.com/vb/showthread.php?t=26578 Thank Again
Thanks you so much!
