Need help with brakes
The Icebox
I bought a Manco Express model 606B about 6 months ago. I have done various things like paint, new motor (9hp Honda), 5 point harness, wired lights/kill switch. It has been a fun project and finally have running right. :thumbsup: Now to the point, I ran The Icebox (name from the movie Little Giants) yesterday, taking my son and the kid next door around the block. At first the brakes were good then as i rode longer and used them more by the end there were no brakes. What can i do to fix this? It has a manual disc brake set up. Manual meening the rod from the pedal to the caliper not hydraulic. When i finally get it on the trails it would suck to constantly have to stop and tighten the brakes. Am i missing something here? Is this normal? Also how would i attach a pic from my phone? Thank you for the help in advance!
88nightrider
Norway, Sandnessjoen
I don't know about your brake problem :(
But to upload pictures you could try:
One way to do it is to "Post Reply" (not "Quick Reply").
Go down to "Additional Options". "Attach Files". And you can upload pictures there.
Or check this thread: How to post pics
Hello and welcome.
The mechanical brakes typically have one pad glued to the side of the caliper and the other side is free to move. The mechanical calipers need to float on the mount to have a proper braking.
This sounds like the brake caliper is fixed.
Post some pic to see what might be the problem.
jandj
Williamsburg, Va
The Airheart juice disc set-up I'm using on the Superdart resto operates the same way. My personal experience is that it's easier to float the disc than the caliper....others may disagree. Pics are a must.
The Icebox
I was able to mess with the brakes today and I think the issue was the caliper being loose. I tightened everything up so hooefully that will work better. I do like your idea though Felineman. I took it around the block a couple times with my son and nephew it seemed to stay tight. We shall see once I get it out on dirt. Thank you all!
The Icebox
Where it bolts together. Sorry no pics taken so I can't upload them. If you are familiar with the type of caliper there two bolts that keep it together. Both of those we're loose as we'll as where the brake rod connects to the caliper lever.
The Icebox
Lol yeah pretty much. I just tightened them for a quick fix to take my son and nephew for a ride but I'm going to put a lock washer or nut on them to help from coming loose on trails.
KartFab
Dallas, TX
Try locktite (aka a thread locker, blue)
Also where you adjust the brake pad in and out, there should be a retaining nut. After you adjust the bolt, tighten that nut down, which will prevent the bolt from backing out.
The Icebox
I had taken the caliper off a few months ago to clean everything and check the pads. After a few rides it would do what it is doing now.
J_Walker
Florida
Simple fix.. use some electrical wire, wrap it on the threads, basically its keeping it from backing out. of course loctite would do the trick too, but electrical wire is cheaper.... its like a cheap, DIY cotter pin.
The wire thing will work, when it comes to serviceing later, the threads will be buggered up from the wire being work hardend and mashing the threads.
