Need help with axle end?
Kevin90GSX
Go Kart n00b
Connecticut
Hey guys!
Need your help. My brake drum on my go kart decided to end itself:
I got the wheel off with no problem. Then there was a pipe spacer that led to this part:
Clearly the fastener in the keyway had rusted so I had to cut it off. Now I cant seem to find a replacement. Its not a hub cause there is no bearing. Its just a piece of metal. The hole in the middle is 1 inch and on the back is another circle that the sprocket rides on thats about 1 5/8" give or take.
Does anyone know where I can get that piece? Im not having much luck with google.
Thank guys appreciate the help!
Kevin90GSX
Go Kart n00b
Connecticut
I dont see the one I need there. Man will I have to get a different design and will it even work? Will I need to possible extend the pipe spacer?
Kevin90GSX
Go Kart n00b
Connecticut
Well its weird cause the brake drum and sprocket bolted to the hub. The center hole of the drum wasnt the same size as the center of the sprocket.
Does that make sense?
Research "split tapered hub" and similar. I believe that's what you have. I can take a picture of an example that I have, in the morning.
