Need input on hydraulics...…..Wanting a master cylinder/caliper/20" hose setup for $21, and replace the hose with a 86" for $12 (free movement of swingarm).
Really want a remotely mounted reservoir ($5), where obviously you can add fluid if you have that setup. Problem is in getting a tube for it to attach to the master cylinder. Pictures of masters that come with a reservoir show an odd looking connection that seems to be where the sight glass on assembly above is, but those would require buying a separate caliper, price keeps climbing here.
Any ideas how to replace sight glass with a tubing connection? And I'm only guessing that you're supposed to pop out the sight glass and funnel in some fluid if needed on setup above. Help help!
