ghost civic
I tried getting help in some snowmobile forums, but got nothing.
I got a mid 80's Yamaha excel 340. It isn't in bad shape and the guy sold it for just $40!!!
So no the problem. The sled will start FIRST pull...but after you rev it a bit the amount of smoke increases...the idle will slowly drop and then stall. You can keep it running with some throttle...but to much throttle and it bogs really bad.
Try to restart it, and you will have to give it some throttle to start and it wont idle.
Plugs look like they are being oil fouled.
Give it some time to dry out, and it will start first pull again and repeat what it did before.
The sled is oil injected. I wanted to check the linkage to the oil pump, but 1 screw stripped on me. That said, if I move the throttle back and forth I think I can feel the rotary slide in the oil pump move through the case.
But, thinking maybe the linkage was busted and the oil pump was wide open...I removed the lines from the pump to the intake runners and then ran 1 line between both runners (to close them off) and then I put mixed gas in the tank.
But alas...the same thing happened. This time the plugs don't look as bad, but the motor is doing the same thing. Starts first pull, rev it up and get more smoke and then it wont idle. If you start it and just let it idle then it will idle for a fair bit of time without any problems(if it hasn't been run in a while)
Any ideas? Could there be some seal that has gone bad and is allowing extra oil/fuel to get into the cylinder? I got 110psi on both cylinders.
I am at a loss as to what I should try next.
