Need help starting my go kart
Josh904
I have a 212cc predator motor on a go kart frame. The motor is somewhat new. Has ran fine until today. Started it up this morning fine. Then went to start it up earlier and wasnt starting. Ive cleaned carb and checked to see if gas is getting in carb, gas is getting to carb for sure. Havent pulled spark plug but ive put a screw drive in it and it is getting spark. Whenever i go to start it, it sounds like it wants to start but just doesnt. Any ideas on what i should do next?
Spark, compression, gas.
If it sat for a long time, and ran when it was parked, I suspect fuel issue.
I'd first pull the plug, install plug in wire and pull rope. Do you see spark?
Put thumb on spark plug hole. Pull rope sharply, does it pop your finger off? (Stuck valve would leave no compression)
Reinstall plug, choke carb, fuel on, pull over a few times.
Does it sputter or try to? Pull more. Smell gas? Pull plug and look for moisture.
Carbs have tiny holes that require a thorough cleaning. Small wires and good solvents and compressed air.
Is the kill switch in the proper position?:roflol:
