Need help removing torque converter
Evh2323
Trying to get off torque converter driven from shaft and it won't budge, I've tried using a gear puller and it didn't work and during the proces it bent the torque convert, does anybody know how to get this thing off?
jamyers
Buffalo Gap, TX
I'd try removing the bolt from the right-hand side of the jackshaft, and see if you can get the driven AND shaft out of the housing. Then it'd be easier to drive the shaft out of the driven unit than pull the driven unit off the shaft.
I'm assuming you've done the usual soaking in penetrating oil, etc?
Spray can- Releaseall, WD-40, Fluid Film, Forte, or a half-a-zillion others.
Is there a nut on the far right side of the jackshaft? Remove it, and try to drive the whole assembly out to the left.
jamyers
Buffalo Gap, TX
There has to be some method of retaining the shaft, generally either a nut or a snap-ring. Otherwise you'd never be able to service/ replace the jack shaft bearings.
