New member, first post, newb, blah, blah, blah.
I have a stock Predator 212cc w/hemi head.
What I need is some advice on keeping the engine stock but making slightly more power. Sounds crazy huh....
The race that I will be running is oval grass/loose dirt. Everyone is required to keep the engines stock. This means no intake/echaust/spark plug/etc upgrades. Only things we are allowed to do is remove the governer springs (not internal) and hook up the throttle to allow it to be wide open. Fun, cheap, competitive racing that makes it more about the kart and driving skill.
I'm thinking about what I can do to help the engine gain an advantage without modifying anything and this is where I have struck out on the many searches for the right answers.
Few things I've thought about would be using the best oil, best gas, 140 e-tube with stock jet, disconnecting the oil sensor, lifting open the stock airbox slightly to allow more airflow, taking the heat shield off to allow exhaust to flow out the bolt holes, and that's all I can come up with.
I've got a badass oval racing kart that had a methonal 26hp B&S Animal on it. It currently has 11in dirt slicks on it and a 68t sprocket. The kart came with a Tomar racing clutch w 12t sprocket.
I will need to put bigger tires on and swap the hubs to a 4/4 or 4/11 bolt pattern to allow for 18" tires all around to give me enough ground clearance. For this I am thinking about buying a small parts ATV for cheap and using the tires. My idea is to get a 6.8:1 gearing ratio with a 10t clutch sprocket because I'm a big boy and need the acceleration help. The oval track we are gonna race at will have a few bumps and whatnot because this is literally in a backyard that is not race prepped. The track will have about 150ft straights and want it to be at top speed before entering corner on each straight.
I am still in the R&D phase here but we are running in a month or so. Just for fun, no rules other than stock HF predator 212cc engines. That means lots of rubbing, cattle prods, spotlights to blind each other, etc. It's gonna be fun.
I just need some help from you guys to get the build the best it can be without breaking rules. I haven't found what I'm really looking for yet and wanted some input for my situation.
Thanks in advance for the help!
remove the gov, or don't touch it.
