Scarface
Ok, thanks. I put wd-40 on that driven today and I will try and get it off tomorrow but you also said take a "hot wrench" to it, what do you mean by that?
Are you bumping your thread every 30 minutes? Please don't do that. You are not going to get any help any faster. It actually annoys people and you could get less help.![]()
I bumped it after 12 hours...
Ahhh. My bad....
Just- please- don't do it. When we get there, we get there...
is it a snap ring? just pop it off with a screw driver and some needle nose pliers. that should work.
The forums I have been on have a thing where when someone edits a post down at the bottum there will be little letters say last edited then the time it was last edited. But this forum does not have that, but if it did you would realise those ...(3 dots) was not me bumping it because I basically just deleted my post.
The first post with 3 dots, I was asking about where to put the flame when I heat it up. 12 hours later (the second post of 3 dots) I put ^!?, because no one answerd my question, so yes i was bumping the thread so maybe someone could answer the question, but I got home and no one answerd it and since I already tried heating it up my question did not mater anymore, so I basically deleted my post and put ... instead.
So the two post that have ... was not me bumping the thread it was me deleting a question I had that did not matter anymore. So next time i will type deleted post when i want to delete a post.
You do not need to type "deleted post" or delete the writing you had. All you have to do is click on the edit button (like you were doing) and then click on the button that says "delete post". This will delete your post. It won't even display anymore.
Regarding the time etc at the bottom saying your post was edited - it only inserts that if you fill in the space for reason edited. If you give no reason, you will not get that little disclaimer thing at the bottom. If I hadn't typed in "Added Image" in my reason for editing, it would not be there. Try it out
So I have this sprcoket, it is a 12 tooth and I want to try and find 8 tooth. I did some searching about sporckets yesteryday. The hole is 3/4" diameter and is keyed. All that I really got was that I think this is a type B sprocket. I just need some help finding the same kind of sprocket just with less teeth or need to know what I should be typing into the google search to find the sprocket I want because from looking yesterday there are millions of options.
You should read the sticky on CVT maintenance.
Regarding that 8T sprocket- good luck. You're going to have a bugger of a time finding that in a 3/4" bore size. I'm not even sure they exist.
I'm Also in the same boat trying to figure out sprocket sizes, also ground clearance. Gonna run a motor between 5hp and 6.5hp would like it to be quick off the start but also have good top speed, the kart I got had a small engine and a 16T shaft sprocket and 30T axel sprocket on it, I've been told that would do nothing
