Need help on clutch!
rodney01
i have 208c cmmx engine. i dont know how to connect the engine to the rear shaft.
I am assuming that you are asking how to connect the engine to the axle. You will need a clutch, some chain, and a rear axle sprocket. You will need to make sure that the ratio you end up with is good enough to move your kart. The ratio is calculated by dividing the number of teeth on the clutch into the number of teeth on the axle sprocket. You can either use a centrifugal clutch or a torque converter
A general rule is about 6:1, but this depends on a few things that you will need to tell us. They are tyre diameter, kart and rider weight, as well as the terrain you are going to be riding on
I see you are from the Philippines, so things might be hard to come by there, or expensive
