Need help manco deuce
Jairo
Waco, Tx
Hi im new to go karts first one i own first one i ever drove that has shocks so i bought it really cheap but the tecumseh it had broke sown so i bought the kubota zx340 drove it once and the trans started slipping shut it off tried it a few times neither gear would work u can hear them grind at first but nothing so i figures the trans went out now where i need help os idk how to fix it to make it a live axle even if i lose the reverse ImageUploadedByTapatalk1431033817.833728.jpgImageUploadedByTapatalk1431033832.482797.jpgImageUploadedByTapatalk1431033851.399187.jpg
firemanjim
Just kartin' around....
Houston Texas
If you just want to make it live axle, buy an axle the same diameter and length as the axle on there now. Then you need to make a jackshaft to mount the driven clutch and a drive sprocket.
Post more pics of the trans. Maybe it's something easily fixable....
Jairo
Waco, Tx
Yep but idk what gearing or what all to buy to run with a live axle cuz to me it sounds better like a posi on a car but then idk whats better so i need advice
firemanjim
Houston Texas
It IS like putting a posi in a car.... :thumbsup:
Maybe "we" should look at the trans to see what's wrong, and if it's an easy fix. Depending on the type trans, you might be able to get a replacement fairly cheap. Can you post some pics of it, especially with any serial / model numbers....
firemanjim
Houston Texas
Jairo
Waco, Tx
From the ground to the topof the back its 22 and my motor is a 1" bore
firemanjim
Houston Texas
Your driven clutch, has either a 3/4" or 1" bore. (not the one on the engine.) Youre gonna need a jackshaft for that to mount on.
As for gearing, I don't know first hand, but I'd say you're gonna want to shoot for a 7:1 -8:1 ratio.... Someone with better, first hand experience with karts and large tires, will chime in soon.... :thumbsup:
firemanjim
Houston Texas
The clutch on the engine, is called the drive or driver clutch. The one on your transmission is called the driven clutch.... :thumbsup:
