Need help making a bracket
As the title says. I have a mill and a lathe. I'm trying to make this part but I'm having a little problem with it.
Any help would be appreciated!!!
anickode
S.E. Michigan
You need to use an Escher Chuck with a Mobius turret adapter on your lathe, and a Euler endmill with a 4 dimensional cross slide. Thread pitch is probably √-1, so you'll need a set of Fibonacci change gears.
If doing this on CNC equipment, you'll need to use ID-10t programming language instead of standard g code.
TT540
Newb
Huntsville, AL
haha. Took me about 30 seconds to call BS. But's only 8am. I need to use that one on some coworkers.
Edit, wow, that is a nerdy drawing. Pi is required for the nuts. Pi-nuts. Pine Nuts.
