Need Help finding a part!
mcrende
Hello guys and gals, this is my very first post on the forum.
I have a 48cc 4stroke engine with a Dekni pz19 carb. I got it off of craigslist for a steal, but the carb is missing what i believe is called the throttle valve (correct me if I'm wrong).
I searched high and low on the web for it and all I can find is a complete carb.
Here is a picture to show what I'm looking for.
I need the plastic tube thing the metal collar that threads into the carb and everything inside of it, which I believe is the tapered needle a couple of springs and ???
Thank you!
KieranM
Doin It!!
Kilkenny, Ireland
I take it you need, the needle, little c clip,spring, piston/barrel and that little plastic tube. I have a pz27 carb and it is similar to that one.
Its a copy of a mikuni, search 19mm mikuni and you should find what you are looking for.
Dekini, standard of japan, are copys of mikuni
solomon
ca
It would be most likely be cheaper to replace the whole carb than find the individual pieces.
