Need help figuring out what type throttle cable to get
r.etheridge
Im a newbie to go karts and I picked up a frame for my kids. we stripped it, repainted, made a seat ect. I got a b&s 5hp model #135202 with a 3/4 in shaft from a guy. Now, we need a throttle cable for it and im lost. I took some pics to show everyone what kind of frame set up I have. The screw looking thing is hollow, and was on the kart where the L shaped bracket is. The bracket has 2 holes in it. This kart is just for my kids to ride around the yard and stuff like that so im not looking to spend a lot. The gas pedal also has 2 holes in it. Any help and links to what I need would be greatly appericated!
r.etheridge
pics
Welcome to the forum.
Those pics are great for detail but, not the details we're looking for; it's difficult to gain a perspective. Can you take some pics of the carby, both close up & a bit farther away so we can judge what we're looking at
Much better, thanks.
Now, as landuse said, you can use a bicycle brake cable, including all the bits & pieces, mainly, the adjuster. Connect the adjuster where I've labelled the pic "mount cable anchor here". then, carefully drill a small hole in the linkage and attach the cable end where I labelled "attach cable here" & put a return spring from the hole where the linkage rod goes to... something solid along the same line as the linkage. Attach the other end to the throttle pedal & you're good to go :D
qtband
St. Louis, MO
Do you have a picture of what's under the carb? My B/S set-up is connected under the carb. Also, where are you located?
Based on the pics, no, it's different. Qtband has a gravity setup (carby under the tank), r.etheridge has a suction setup (carby on top of the tank)
r.etheridge
where can I get the spring your talking about? im assuming it needs to have a good bit of resistance?
That you'd have to investigate yourself. For starters, I have no idea where you are. Any good auto parts store should stock them; just ask for a throttle return spring. Get a measurement so you have an idea what size to get
I am going to have to disagree with you here Fabroman. I have a briggs 5HP engine that has a pulse jet suction carb on the tank, but has a throttle setup under it like Qtband. Qtband also has a suction carb:D
