raposak
2012 Build-Off Winner
no way to do it without the jackshaft. I'm using #50 chain which is much beefier than the standard gokart chain.
Speed is good, but I also need stump pulling torque. I want to be able lug the engine up a hill without feathering the clutch.
Well the 70T axle sprocket is a no-go. The thing is a massive hunk of steel that's WAY too big. I went from originally going with 27" rear tires to 24" tires. Now I have to start over......... Any more help is appreciated.
Well here are the gears I currently have to work with.
Engine/Jackshaft
12
13
13
15
16
27
Rear Axle
28
43
45
72
Like I said, the 72 is entirely too big. I don't mind buying another sprocket for the rear axle, but it has got to be smaller than the 72 I have. With the above sprockets, what would be a good combo to go with?
I noticed r97 suggested using the same tooth count for your countershaft and jackshaft-in. I cant deny or confirm this as a fact, but with all the info you supplied this seemed to be the only gearing to achieve your goal.
