In order to determine air tool suitability, you need to know the PROPER compressor ratings. Should be something like "4.5CFM@90 PSI". You would then compare the airflow requirements of the tool you are examining. IF the above compressor rating were true, you'd have no problem with, say, an air drill that requires 3.8CFM. On the other hand, and orbital sander that requires 5.5 CFM, will not at all be happy with it's new home.
Sometimes, you can safely get a tool that requires more than your compressor can deliver, BUT- you'll find yourself standing around waiting for your tank to recover in between bursts.
