Need engine with pulling power
jdsc
we are working on building a kart that will be able to pull 3-4 trailers with 3-4 adults on it. We estimate total weight would be about 3,600 pounds Think like a parking lot tram.
I would appreciate it if anyone could recommend an engine size and gear ratio for this application. We are not looking for speed Maybe 10-12 mph max) and will be used on a flat parking lot or flat dirt area only.
I have seen riding lawn mowers with around 20hp seem to handle this.
robbie
Osceola, Missouri
I think the Harbor Freight 13 HP engine would do the job. Before you settle on a gear ratio you have to know how big your tires are going to be.
You need a tractor, mate!!!
Kidding. Anyway, I tend to agree with the 13HP thing. Nail down your tire choice, and work from there. Geared low enough, you'll have no problem.
I'm assuming "wagon-type" 4-wheeled trailers with zero tongue weight, correct?
jdsc
yes four wheels on the trailers so no tounge weight.
was thinking tires in the 8" diameter range unless you suggest otherwise.
karl
North east Ohio
You can find an old car Manuel transmission and pair it up with something like a 18hp apposed briggs. Have a double belt tensioner going to a jackshaft, then a universal joint going to the input the the tranny. Then find an old car axle (dana 35 would be plenty) And hook it up with a junk drive shaft. The slow speeds will come from the pullys on the jackshaft. And if you wanted you can easily hook up leaf springs for the rear. All these parts can be found at a junkyard for cheap. Even if the parts are not good enough for the road, you are not going to fast. That is a million times better than a harbor freight engine and you would have gears and reverse.
A functional idea.
Gonna look a wee bit redneck. Heavy as sin, too.
Don't forget about the additional reduction not only in the tranny, but the diff, too...
karl
North east Ohio
I know. I sketched up a vehicle like this awile ago in a note book. I get bored in study hall lol
Don't get me wrong, I'm not shooting down the idea- it ain't bad. I've seen a few homebuilt tractors set up similarly, and the were pretty decent. If the OP's running parades, the look may or may not work.
Bluethunder3320
Go american, get a used briggs. Don't give more money to China
:roflol: yes that is if you dont want to take the easy way out.
just make sure its a cast iron bore. i think my 13.5hp briggs is "kool bore". and if it is, im probably going to part it out on ebay.
