Need Carb size guidance please!
agantt
Wagener, SC
I'm just getting started on a couple of projects and need some guidance if you can. I want to go with Mikuni carbs for both as the engines I have came from equipment that was either at idle or operating at one speed, not what a go kart does.
One is (I think) a Manco Dingo that I have a GX390 that came out of a Dewalt generator. What size Mikuni carb would be best? 32mm?
The other is just a old school two seat kart the I have an 11hp Tecumseh off a snow blower, would a 30mm be best? I'm also probably going to need to convert the rear end to live axle as single wheel drive with that much power will never get traction.
I'm very new to carts but have built 6 cars from ground up. I really would appreciate any and all advice!
First thing, does the motors have a straight keyed shaft to mount a clutch.
Most pumps and geny's have a tapered shaft, they can't mount a standard clutch to it.
agantt
Wagener, SC
Luckily enough the shafts are straight, keyed shafts. I have the measurements out in shop. It is a Manco Dingo, someone welded extra cage over to the cart.and that was throwing me off in identifying it.
