I got that as well while I was sitting in Biology today and I had to double take. I wonder what axle the hubs are for as it says they come with hubs. If they're 1" ID with 1/4" keyway I'll get them. Does anyone feel like calling BMI?
I am looking for big tires this is awesome! But how can I be sure that it will fit my setup? I do have a 4 bolt pattern so that seems good what else should I check for?
The ad reads: "Rim: Bolt Holes are 10mm, Bolt Hole Pattern is 4 holes on a 110mm Bolt Hole Circle". Thats 4.33" a standard go-kart wheel hub has a smaller pattern. The 4" hubs may work but can be expensive.
