Need Bent Tubing
Shotgun
Fabricator
Northern Oklahoma
I'm looking to fab an intake and an exhaust header, but there is absolutely nobody in my area any more, that can bend 1¼" O.D. tubing.
I don't need anything fancy, just 3 pieces of welded steel tube, with a wall thickness of around .065" or so, each with a short-radius 90.
If anyone out there can help fix me up with a few pieces like this, I would really appreciate it.
Steve
Steve
How about $10 each?
http://www.nrracing.com/product-p/bends-1.250.htm
1.25" 90 degree bend
The internet can bend anything because it uses Wonka Vision. How tight of 90 do you need? I can find stainless ones with a tighter turn, but more expensive.
1 1/4" O.D. X .065 WALL (16 GAGE) 90° ELBOW 2 1/2" C.L.R., S/S 304
http://www.sharpeproducts.com/store/stainless-steel-1-14-tube-90-elbow-25-clr?productId=13956
Outside Diameter (O.D.) 1.25 in.
Pipe Size or Tube Size 1 1/4" TUBE
Material Stainless Steel
Thickness .065" (16 GAGE)
Wt.Ea. 0.27 lb.
Degree 90 °
Centerline Radius 2.5 in.
Inside Radius 1.875 in.
http://www.ebay.com/itm/1-1-4-1-25-...ash=item3d34d6ca6e:g:FL4AAOSw32lYuaFY&vxp=mtr
