sno-kart
- Messages
- 120
- Reaction score
- 0
We put the engine, rear axle, and clutches on yesterday to figure out how we are going to tension the chain and we ended up scratching our heads a bit.
Our setup involves a jackshaft with a 530 chain to the rear axle (see pictures). Since our rear axle has some movement front to back, we were hoping we could do this without any sort of a tensioner. We looked up a formula for how much slack there should be in a chain and the best I could find was on a dirt bike website, which stated that the amount of slack between the two axes should be 1-3% of the distance from axis to axis. So our distance from the jackshaft to the rear axle is 12". 1-3%of that is 0.12" - 0.36" so basically 1/8" - 3/8" which is a very small amount. When we positioned the rear axle to where the chain had about 3/8" movement of up and down play, the chain seemed very very tight and the rear axle had a lot of resistance when trying to spin it.
Something doesn't seem right so we figure it's better to ask. How much chain tension should we have in our setup? Is the formula we are using applicable to our kart?
Thank you!
Thank you!
