gguuyy
It's not over geared, if anything it's undergeared. It was reaching top speed in the first 50 ft or so but now that I've removed the governor its a lot better. Im pretty sure it's faster than 21mph but may not be, hard to guess when ur so close to the ground. I think I may go with a 12T clutch sprocket and than leave it there.
One problem I have now is that it won't rev with the high flow filter and straight pipe but when I put the stock air filter back on it runs fine. Do you guys think changing the jet will fix it?
