HeWhoAngersYou
This is a short video of my Manco Magnum Express Kart project I am currently working on. This Kart will have a 84 Honda 200s ATC motor and 5 speed drivetrain. The 11 tooth sprocket coming off the gearbox is a 520 pitch 11 tooth sprocket. and 4" set back from where I would like to be. was thinking of going 11 tooth to 11 tooth jackshaft in 520, then to my 35 tooth 520 driven sprocket. My Questions are, What do you see being the best way to connect my setup together 2. If anyone has mounted a set of ATV tires 22x11x8 on a magnum express kart? 3. Has anyone built anything close to this in the forum and how did it work out? Thanks in advance guys.
got the answer to #2 already and the answer was yes and it looks bad azz.
Heres a link to the video:https://www.youtube.com/watch?v=rWcqeguNlbc
thanks in advance.
thanks in advance.
is that the one with 5 high 5low gearbox, like mine? I know mine is a 200 from a Honda atc, but don't remember which one..... I got some pics of what I was working on, somewhere on this forum. I put one on a crossfire kart. It too will need a jackshaft to put the drive chain behind the axle, then to the axle. The chain can't go straight down, the engine sits almost exactly like yours does.....
