Hi,
We recently bought a used Mini Dwarf to race at a dirt oval. I was not as familiar with the Briggs as I should have been and it turned out that this engine had an aftermarket carb (Mikuni) to run in the modified class. Since we are starting in the stock class we need to reinstall the stock carb.
So I bought a stock Briggs carb (#798653) but am now completely puzzled as to how to mount it. First the carb hit the heat shield, so I figured that I needed a carb mounting plate which it appears to be nothing more than a spacer? Now where I'm really puzzled is the throttle. I need a spring return and to attach the existing throttle cable. Is there a mounting plate to make this happen? How has everyone else done this? The butterfly valve seems to work backwards as to how I think it should. It needs to turn clockwise to open which puts the throttle mounting points right up near the engine.
If anyone has any pictures of a stock carb set up with the covers gone I would really appreciate it!
Thanks!
Thanks!
