my snowmobile powered go kart build
stretch8668
I have a murray explorer go kart that lacks power. I ended up getting a 85 yamaha xlv for free motor runs but needs to be rebuilt. Gonna use motor and both cluthes exhaust and ignition. One problem I noticed is the secondary clutch is splined and the jack shaft is to big for go kart. Does any know how I can have a jackshaft splined on one end and keyed on other BTW ITS A 540cc ENGINE.
qtband
St. Louis, MO
Do you have the karts jackshaft? You can cut it cown and have the end sized on a lathe and keyed. A machine shop can do this. OR...if you have the snowmobile sprocket, cut the center section (with the splines) and weld it to a sprocket.
stretch8668
The karts jackshaft isn't gonna be long enough for the snowmobile motor and yea its a lil over on power but it was free for the whole sled. I might try and use jackshaft outta sled just get it cut down lil and keyed for my sprocket with threads on it and I'm thinking bout useing two sprockets and chains.
exenos
Project Nut
That 540 is 56hp, that's just not a good idea. I don't remember what the thread was called but we just went over this subject a while ago. These karts are not designed for the power and speed of a larger sled engine. Its just not safe, look up djeepers death trap and you will see what just a 18hp will do with that kart.
You should just sell the engine or trade it off for a smaller engine. Try to trade it for two smaller ones if possible, you'll live longer.
exenos
Project Nut
I agree that this idea is far from the worst that has been posted here, but I still feel the need to stress that 56hp in a kart with no suspension, no proper steering geometry ( that I know of), is made with thin wall tubing is far from a good idea and is approaching the "insane" area of most peoples thoughts. (Including mine, and I'm about as cuckoo as they come)
Dude, I'm not disagreeing with you, I also suggest the OP at least do something to improve the steering & use some bracing where needed; at least greengoblin did that much...
exenos
Project Nut
I know you aren't disagreeing, didn't mean for the post to come across like that. :cheers2:
rocketkart
florida
i used a xz1000 kawasaki engine in a small carter brothers one seater go kart one time and rode it one time and now it sets in the shed never rode it again. lol
stretch8668
Decided not to do it but what would be good motor to put in it that'll be practical and still get the tires loose on dirt.
Please note the edit button in the lower right corner of your posts, use it as opposed to multi posting...
I would think any engine would be better than a 6hp tec :lolgoku: But, without major fab work or dropping large amouts of cash on a 1" clutch setup, I think the best option you have is a hopped up predator...
If you don't have a problem with either of those conditions, either a big block predator or a pit bike engine (around 150cc 4 stroke with multi gears)
exenos
Project Nut
I second the pit bike engine if you like banging through gears. Otherwise a small 250cc single cylinder sled engine would work well also. Only around 15 hp so it would be just about right for that kart.
