After getting my 5yo daughter an electric gokart I needed something I could ride around with here.
I was originally going to convert a gas buggy to electric and found a Mango Dingo 285 for a good deal. I then spent tons on a high power brushless motor, 96v controller, and 14 prismatic lithium ion batteries from a Ford Energi. Next I began to slowly realize this was getting out of control.
I aborted this plan and joined the Power Wheels Racing Series Facebook group. Here you have adults that build gokart chassis that fit under toy car bodies. They are limited to 48v and 30 or 40 amps. Most cars run between 15-20mph and the racing is competitive. Most of the racers use the ~$135 48v boma style motor and controller combo so I figured it should be good for me also.
People here recommended the Razor Dune Buggy and I finally found one for $75 after three months of searching. I had already bought a welder for working on the Manco so I began to make a motor mount for the 48v motor. I am still using the stock jackshaft but upped the motor sprocket to 15t from the stock 12t.
Besides the motor mount, I also cut and re-welded the top uprights so I could put half of the battery pack up top and the other half is where the two stock 12v batteries use to be.
The only other mod is a new thumb throttle with an on-off switch and voltmeter. I'm not running any kind of BMS, I use a hobby grade battery for charging and individual cell checkers with audible alarms when driving
All up weight is 84lbs which is far less than the just the Manco's chassis and wheels.
Top speed on the flats is ~17mph with my 200lb frame and it easily gets me up inclines. I have 40amp fuses coming from each battery with 10awg wire. Nothing is hot when I'm done, motor is warm but that''s it. The batteries have almost 20ah and I could probably drive for an hour before needing to recharge. The batteries are wrapped in foam floor tiles cut to fit and strapped to the frame with velcro.
Next goal is to add mud flaps over the rear wheels.
Next project is to buy another one and mod it with larger tires and a standard 35t sprocket setup.
