My Project for this year...looking for your thoughts.
xafsf
I bought an off-road kart a couple years ago and never got around to getting it fixed up but I want to try to get something done with it this year. I am not sure if the manufacturer of this kart, not that it really matters. Although it has a few rust spots it is in decent condition. I paid $400 for the kart as it sits in these photos. I was planning on using at 13 h.p. from Harbor Freight. Originally I wanted to use the engine from a snowmobile but It is not running and I don’t really want to sink more money into it just to see IF I can get it running. In addition to HF engine, I want to utilize a gearbox from mfgsupply.com so Ill have a reverse gear. I plan on running the kart in a hilly part of eastern Ohio and my kids will eventually take it out on their own so I wanted to make sure it had reverse to help them get out of any “situations.” Depending on where on the property they go, it could be a long walk back to the house to get help. (side note: maybe it would be a good idea to keep a small radio on the kart…just in case). I’m not too terrible concerned about speed since the kids will run it and with the hills, I think more torque would be better anyway so I want to make sure it is geared appropriately. I have not ruled out a torque converter but it is not necessarily required and I already have a good bit of $$ invested and there is going to be quite a bit more spent just in the engine and gearbox. Not to mention I will probably need to sink additional money into making sure the brakes are sound and the seats and restraints are safe. BTW, although I am not a mechanic I am mechanically inclined. The kart is located at my in-law’s and my Father-in-law is a heavy equipment mechanic and an experienced welder. I’ve included links to the parts I’m looking at and I’m willing to listen to any advice this board can offer. I know you have all seen these parts before and some, if not most of you, have experience using them. I have read through many other postings and you all definitely seem to be the experts. Fire away with thoughts, comments, and advice. It is appreciated:
Engine:
http://www.harborfreight.com/engine...hp-ohv-horizontal-shaft-gas-engine-66525.html
Gearbox:
http://www.mfgsupply.com/m/c/218390A.html
(Possible) Torq-A-Verter:
http://www.mfgsupply.com/m/c/218352A.html
Looks like a fun little ride and I'm sure the kids will have a ball. The reverse box is a pricey piece, but options are quite limited if you really want reverse. If you can spare the change, get a CVT (torque converter). Unless the kart's geared quite low, the combination of kids driving, and hilly terrain will wreak havoc on a centrifugal clutch.
Either way, keep us posted on the buildup, and good luck! Oh, yeah- Welcome to the forum!
daniel7250
For the money you intend on spending, you could get a brand spanking pit bike engine and put in this. id say probly a 140cc they put out about 13hp ? plus 4 gears. you could swap one of the gears out and put reverse in. and even a semi-auto clutch. Put a larger carb on it and a big bore exhaust.
Bluethunder3320
for the price of a clone, torque converter, and gearbox, how about an old ski-doo engine or arctic cat???
daniel7250
well i had it done by my uncle. ill try and find a like to the kit for you . but it is possible, as i said because we had it done to our quad .
xafsf
Great information and ideas, thanks. And keep them coming. Here is the motor I was originally planning on using but I'm having trouble getting it running. It has been a while since I tried but I think I was getting spark on only 1 side. I suppose that could be the coil which I can replace for about $25. Using this would also mean no reverse. I could forget about the reverse and keep a small winch on the kart. My fear is that one of the kids will get stuck against a tree heading downhill and won't be able to push the kart uphill enough to get free. Both kids are pretty dang smart. I could teach them how to safely use the winch, or better yet(for safety) a ratcheting come-along. Or, like I mentioned before, they could hoof it back to the house(or call on the radio) and Dad or Grandpa would be on our way to help out. It's just that I can see that getting REAL old about the 3rd or 4th time they get stuck.
BTW, if I remember correctly, this is a 440 Cayuna from a '76 or '77 Scorpion Whip.
Bluethunder3320
hmm it should run with only spark on one side. but you really want to replace that coil.
i say use the sled engine, you could get a reverse gearbox if you really want.
element10554
Glen Mills Pa
Looks really cool keep us updated on your choice of reverse I myself have contemplated getting a reverse gearbox or "other" application. Good luck
