My Mini Belly Tank
jrb56
Buda, TX
So here is the picture I promised of my project...
So far for the front, I have a 36 Ford axle, spring, and spindles. Also Model A hubs, wheels and tires. Still have to get my raduis rod/whishbones to hang it...
The engine is a 340cc 25 hp CCW/KEC snowmobile engine.
I am planning on running a Comet clutch (94C?) with a jackshaft to a chain.
For the rear end I have a Model A, but empty with chain driven axle to matching hubs/Model A wheels.
The frame will be built out of 3x2 and plate to hang suspension/motor...
I will need much help figuring out the best/cheapest way to clutch/jackshaft this so it can exist in parades, but also make a few high speed runs...
Joe
fowler
Bullsbrook West Aus
This looks like a really cool build
Have a look a split sprockets
Let u change sprockets fairly quickly to get differant gearing
jrb56
Buda, TX
Split gears, noted...
Yes, the engine will be enclosed. I do have some ideas for cooling...0
Joe
Lokis_Tyro
Changeless Madman
Wisconsin
I'd really like to see more of this. It's like a formula ford crashed into a soapbox derby car. Sweeeeet!
jrb56
Buda, TX
So just a quick update - I have scored a Kawasaki 300 Prairie ATV. i will be using the engine, trans, differential, and rear drum brake off of the atv, as well as the wiring and most of the controls. So now I have to sell off my 2 stroke engine and will start working on the frame over the Christmas break.
firemanjim
Just kartin' around....
Houston Texas
That engine won't fit inside that body. I believe it's a little too big. IIWM, I'd use an 8hp (highly modified to 12-16hp) with the tank relocated and a fuel pump. I'd use a top name brand clutch (cc) to handle the power..... That would be a screamer because it would still be fairly light, and the COG would be lower as well......
EDIT.... MAYBE use a torque converter.....
dengieboy
Essex England
water tank?
That body is as mad as a brush were did you find it? and what was it in the past? going to watch this build looks very interesting very retro and old school which is the style i like i wish you the luck of the spanners my friend
jrb56
Buda, TX
Update
Thanks for all of the support... So just another quick update. Drivetrain out of ATV. Looks like it was made to go into the belly tank. Next step, build the frame from 3x2. A couple of answers, this was a drop tank but not sure what aircraft. It was sitting by a buddies shop, and I purchased for this exact purpose...
