My Kart!
Bighomedog11
I just got this kart from a few weeks ago for 35 from a guy on craigslist. The frame was broken/cracked in some areas.. But it was fine because my friend had a welder and he re-welded the broken spots so they a real strong. It came with the roll-cage but it was off when i got it. I put the roll-cage on and it makes it look a lot better and more expensive! I did not put the middle piece on witch was the headrest. This kart is Live Axle also! I need to get a bigger sprocket for it though because it takes off sloww.
Blazkowiez
Kart Aficionado
Houston, Texas
Cool Manco LXT. When these karts were new they came typically with series 30 torque converters which could speak for the slow take-off with a standard sprocket, you can however get a sprocket which will compensate for the 16" tall tires. If you can afford a torque converter you will be very happy with performance.
Bighomedog11
I cant afford a torque converter rite now though..
But will a bigger sprocket like a 72 fix the slow end take off?
Because rite now with the 60t sprocket it takes off like a snail.
