My Kart won't start ! Oh no !
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Sorry for the deceiving title ;)
Hey. I've been working on a go kart of mine and I put a 2004, 6.5 GX200 pressure washer engine on it. Long story short, I soaked the carb in lemon juice for a few days and reattached it. I didn't exactly use compressed carb cleaner or wire to poke/blast the holes so this might be one solution. Last night I started the engine up- mind you it has a new air filter, plug, tank, and oil so it's in good shape- after starting up, I was disappointed when the engine died after I gave it some gas. It seems to surge when it idles. When I say surge, I mean smoke comes out of the muffler and it gets close to dying out- much like choke- then a few seconds go by and then it idles somewhat high, then back to normal. Very strange. I can get it to run full speed by using the throttle lever very slowly and increasing it. If you suddenly open the throttle, it dies.
It also seems to make a hissing sound around the spark plug. Could this be a factor? Should I use my old spark plug to see? The engine ran perfectly before I cleaned the carb. >.<
Bluethunder3320
you didnt have to clean the carb if nothing was wrong! lol
the hissing is normal, its the compression release for starting. (camshaft opens exhaust valve slightly during compression for easier starting) make sure the spark plug is tight.
this may be the problem- did you reinstall the carb gaskets correctly, and are they in good shape? if they are backwards or missing or torn, this will create an air leak behind the carb and it will run very lean.
