My go kart
Skoko
Hey guys , my go karts been coming along great but its crunch time because I have 1 week to finish and still so much work to do.
One question i have is, that my rear axles shaft is 5/8s and my bearings are 3/4s i did this because the 3/4 wouldn't fit into the 3/4s. Now the axle doesnt sit in the middle of the bearing and the rotation is terrible....
I was thinking of buying a new longer shaft that isnt keyed and getting it cut to perfection by a proffesional so that I can just screw the allen key screws into it.
Any feedback?
I can't understand why the 3/4" axle and bearings didn't fit, unless the axle you bought wasn't machined for driveline use. It wasn't just 3/4" bar stock, was it? That'll be waaay outta spec. Tell us more about the parts you bought.
gcarter95
Ottawa, Ontario
The bearings should be reasonable snug. If there is any paint, dirt, or surface rust on the shaft, it doesn't take much to stop the bearings from going on. A fine grit emery paper takes care of it nicely, and really doesn't take too long.
Russ2251
AZUSA:Powered by LAWN-BOY
I'm bettin' this is the problem.
Analogous to buying a length of 2"x4" wood. Not really 2 inches by 4 inches. More like 1½ x 3½.
Measure OD of axle and ID of bearing bore. Digital or dial caliper is essential for this measurment.
Axle should be a "hair" under and bearing a "hair" over. Difference or tolerance should be around .001" to .002" or less. Mine is .0016".
This difference also applies to PTO's and centrifugal clutches.
PTO may be ⅝" and clutch ⅝". If they were exact, they will never fit together. One or both MUST be slightly under (PTO or axle) or oversize (clutch or bearing.)
Skoko
You guys are very correct, I returned that shaft and got a machined one from another metal supplier. This one is just rather slightly under 3/4 and it is a very snug fit, the bearings don't even need to be tightened:p
Anyways, my go kart physics project is coming to a close, and you can bet I will be posting videos of my 1month/100$ go kart:)
Skoko
If your curious the front steering pivot point is using a piece from a wiper blade on an acura, the tensioner system was made because a clutch was 100$, and the front tire pivot points were 3 way steel pipe joints rotating in the squares at the end of the A bars.
