my five bikes
hnick741
ludington,michigan
Here's pics of the five bikes I've acquired I haven't really done anything as far as mods go. Was wondering if anyone had insight on which would be the best to start with.
Looks like they're all complete--no basket cases there.
Do they all run? What do you hope to accomplish? Goals?
hnick741
ludington,michigan
Well they all run the chopper is a little boggy. But I think I'm going to give that to my girls dad. I kind of just want to get better performance e cspecially from the bigger baja bikes clutch just went out of red one.
Iron John
NA
Start with the yellow one. Simple, clean and easy and you will have a runner as the others might be a bit more complex to dial in.
Poboy kartman
Senior Moments Member
White Settlement Texas
The selfie in pic#1 was totally unnecessary....I had already pictured you in my mind....JK....
Welcome to the forum....and we will help you with anything you need to know....(sometimes with things you need done!!!!!)
hnick741
ludington,michigan
The yellow db30 is for my six year old so I'm leaving the 97cc on it but was thinking of trying to put forks with shocks on them for smoother ride and when you get to about 10-12mph it seems like the front tire shakes the bike. I checked the bearings tightened it up any ideas why it does that? And thank you for the welcome and offer of help
Iron John
NA
Spin the front tire with it off the ground and check t see if it is out of round or if the wheel is bent. Spin it to see if it is badly out of balance (the same spot will always stop face down).
You can also try different tire pressures.
Worst case, that tire might be FUBAR.
