my first project "rubbish"
meedo
egypt
sure man as long as oi figure out how to bend two consecutive bends . for example if i have a u bend shape of outer to outer measure of 42 cm how can i mark the tube in order to have the required measure , cause every time i make it it varies sometimes the u shape is shorter and sometimes is longer . this is driving me crazy guys please hellllp:mad2::mad2::mad2::mad2::mad2::idea2:
meedo
egypt
this is the pics of the steering rack mount no more pics as im having dilemma with the upper and lower a arms measurements. as in the previous pic the shocks were too tough making the lower a arm stretched down dramatically resulting in moving of the wheel to the sides scarily when putting a weight on
meedo
egypt
:mad2::mad2:these are some pics after rejecting the front suspension but i think im gonna try harder if somebody could help me that would be awesome:censored::censored:
meedo
egypt
im gonna go on the roll cage and the sides tomorrow , ive a problem guys my rear sprocket is 42T and the engine sprocket is 14T would that make it go fast with the Honda 160 gx 5hp engine
dpaxson
parma heights, oh
you'd go really fast if you had a parking lot 5 miles long. i would go for a 60 or 72 tooth on the back if you're using it off road
Hendersonjk
Arkansas
sweet looking frame! and I was thinking of using the tiller type tires too. are yours on back wards? you were having trouble with your bends using a level or an angle finder like ccrunch said really helps and it probably keeps changing because metal sretches funny some times I made a big "angle coppier" out of two peices of flat bar metal about a foot long and bolted it together to look like this thing kinda
meedo
egypt
today i postponed the roll cage and decided to ride it today it was amazing but takeoff was awful but it was very fast after that . i have to go for a bigger rear sprocket as 72t i think ??.
meedo
egypt
:toetap05::toetap05::toetap05::mad2:frooooont suspensiooooooooon heeelllllllllppppppppppppp???????:stir::stir::stir::stir:
meedo
egypt
yes i just messed up putting them on the right sides. front suspension is driving me crazy
theo
Make a jig for your a arms this way the tubing can be off slightly but with the rod end locked in the jig and the hinge tube locked the a arms will turn out ok.
Meedo- Looking good! I have a question and a concern... Question- Can you please explain the water pump clutch and how it works? I'm just not getting it.
Concern- I'm not sure bicycle chain and sprockets are strong enough!
Good luck, and keep up the good work! Cheers- Chris
