Can you guys help me understand this better please? The calculator on this site http://www.diygokarts.com/speed-calculator.html states that 11/12T clutch with 60T is one of the most common ratios. That was the OP's starting point.
We've discussed this before; that ratio is based on a lightweight kart with small tyres. The heavier the kart, the more torque you need to get it moving. Likewise, larger tyres have a larger circumference &, therefore, again, need more torque to get them moving.
Anything that requires more torque should use a lower gear ratio
landuse,
You said that will cause clutch burning issues. Because of small power engine? With 11" tire, that's only 24mph.
I understand how the calculators work. I'm just trying to understand if you guys were trying to find a way to get the top speed lower due to the age of the driver? Or the engine won't have the torque to get the kart rolling?
My point was base on the age & (lack of) experience of the driver(s).
My kart has 5:1 gearing & has loads of acceleration but, it also has 10" tyres, a worked engine & it's super light; the only reason I can't pick it up by myself is due to it's size, my buddy & I can easily carry it with one hand at the front & two at the back for balance purposes only...
