laminar flow is a totally awesome thing,
and extremely hard (next to impossible really) to achieve..
the venturi in the carb alone almost prohibits that btw.
in order to align all flowing molecules the intake manifold would have to be several feet long.
And that's not actually a good idea at all.
since it alos means that heavier molecules would be allowed tosink inside the airstream, creating an imhomogenous mix.
Since laminar flow means that all molecules not only move at the exact same speed,
but also in the exact same direction
(looks amazing with water.. as if flowing water became a crystal rod)
much easier with tiny orifices btw
laminar air flow feels amazing as if dry light water flows over your hand..
Anyways... the next best thing is reducing sidewall drag to prevent additional turbulences
counteracting the airflow
and the directional patterning prevents most of the tiny swirls counteracting the airflow,
instead the stray molecules jet off in roughly the flowing direction
speeding overall flow up and actually help stiring the fuel mix to keep the mix homogenous
for a cleaner and stronger combustion.
I for the heck can't find that awesome video one once did explaining the topic much better than I could.
It was in the early days where I became aware of "port but NOT polish"
(somewhere in the late nineties.. pre youtube)
I remember it was Beetle tuner so a VW Typ4 engine
(maybe Typ1... but I think 4.. anyways some aircooled four cylinder VW boxer)
he made two perfectly identical sets of heads
ported all four heads the exact same way (rough textured ports) and installed them on identical engines..
producing almost identical hp on an engine dyno...
he then took off the heads on one engine again and polished the ports to mirror finish.
reinstalled he lost -I think- five or six horses.
wait was it one engine?.. ah too long ago... anyways he lost a good amount of ponys
by polishing up his ported heads to prove a point.
and while there was no "shark skin" babble back then, he still explaind the reason very well.
(I think that's the first time I heard the name Schauberger... *shrugs*)
Ah well... nevermind
that's one big hole you got,
so pushing through a sincere amount of combustible gas shouldn't at all be a problem
getting a good pop out the business end
