My first electric go-kart
Maxxpower1989
Heerde the netherlands
First of all i want to apologize myself for my bad english its not my first language.
over a year ago after seeing some youtube video about the neuroti electric kart i decided to build my ow one.
I ordered the basic parts for my kart.
A motenergy 0709 engine
a alltrax spm 48500 controler
and 4 12 volt 50ah deepcycle batteries.
And the searche started for a suitable donor go-kart.
due to some familie affairs and personal issue's i was not able to build my electric go-kart.
a couple months ago i ran into a cheep rolling chassis.
with only some cosmetic issue's.
i starten welding the battery holders in place.
[/IMG]
a week or to ago i started to wire the go-kart
putting the engine on and use a 1/2 chain
and added a small control panel.
last weekend a continued the winring and added the battery's
at the moment i only waiting for the f/r switch witch i was forgotten to order with my engine/controller.
all in all it was a expansive but nice and some times dificult project so far.
Poboy kartman
Senior Moments Member
White Settlement Texas
One thing that makes me go "hmmmmmm"...... I see the instrument panel labeled in English.....for our benefit?
Also.....just curious: Brothers P touch labeler?????
Maxxpower1989
Specs of the motor ,controller and prises .
And a video in action please!:thumbsup:
Hello a video in action need to waith for some time i first need to finish the wiring and i have not so much time the next weeks.
but specs/prices of the motor controller and a few other parts i can give.
The motenergy is a DC permanent magnet motor designed for 24/72 volt.
a 300 amp peek power 125 amp continuos.
weighing around 16,5 kg.
the controller i use is a Alltrax spm 48500 the specs of it i havent laying around but a link to the website.
http://www.alltraxinc.com/Products_SPM.html
the cost zo far are
The compleet rolling chassis € 175
the controller/motor/main contacter/diode/resitor.
was a compleet package orderd from www.evdrives.com
and cost me with shipping import cost taxes and so on to the netherlands about € 1350
the batterys/charger cost me around € 800
The f/r soleniod cost me with shipping around € 180
Switches/0 awg wire/cable lugs/bolt/nuts/metal and so on cost me around the € 350
fore i started with this project i wasent in possession of a tig welder/bench grinder and other tools.
so this also cost me around € 1100
so yes it is a nice but expansive project so far.
Ih82lose
Illinois
I'm about to begin assembly on a similar 48V race kart project and wanted to ask what settings you planned on using when programming the controller? Specifically, what will you set as the maximum current draw? Momentarily at startup, these motors will pull a lot of amps, so it seems a set of 50 AH batteries would get depleted quickly with acceleration. I am thinking of setting mine to a maximum 100A draw, giving approximately 45 min of spirited use with a similar set of batteries.
Will you be charging the batteries with a 48V charger? I was planning on picking up a charger for a utility cart or golf cart, but didn't know if there were better options.
Keep up the good work!
wesleyb82
Long Island, NY
Are you concerned about shorting the controller leads with your leg?? :smiley_omg:
Nice build I am building something similar right now with an etek motor and a Li Cobalt battery from a Chevy Volt which I will post soon. Nice work
This freggin guy cracks me up
kouvpasir
Greece
the cost zo far are
This is going to be fast.....:auto:
