My first build
cerar007
Hey!
This is my first gokart build. For motor I'm going to use motor TOMOS A3 - 49ccm. Some pics... (its my first time with a welding machine)
cerar007
Tnx!
But I have problem with rear tires- they are only 26cm in diameter, i want larger but dont know where to get, because these are small and its going to be low speed
theo
Thought about dual a arm front suspension? You are going to have a lot of camber change with those short a arms. It will be a little more work but will be a lot better.
modelengineer
Lord of the noise
Sydney, Australia
Teeth on axle: 22
Teeth on motor: 26
The kart looks really good, but with that engine and ratio you're unlikely to even move at all. You've got a ratio of 0.85:1 with a TINY 49cc engine. Most people here with 6.5hp 200cc engines run a 5:1 or 4:1 ratio max, and acceleration is hardly mind blowing.
I'd be going with 8:1 or 9:1 to get any accel. at all, and since those motors rev heaps top speed will be alright, but you really need a bigger engine.
cerar007
I dont know where to get bigger engine- mybe from aggregate ?
Teeth for axle i will put on 10 teeth
modelengineer
Lord of the noise
Sydney, Australia
No, you want LESS teeth on the MOTOR, MORE teeth on the axle. Like 10 on the motor and 80 on the axle. Keep looking, without at least a 60 on the axle it won't be good at all.
cerar007
So if i have 26 on motor and 70 on axle will be good. But this isnt agggregate motor, this is rom Tomos week motorbike
i was thinking i need less teeth on axle for speed
Kaptain Krunch
Pro Junk Collector
vermont
Oh so this is a moped engine? still too small for a go kart, but if possible i would just use the same rear sprocket that the moped used, since the kart will be heavier but have smaller tires.
cerar007
Original is 26 on motor and 22 on axle. It goes about 50 km/h. So if i put on gokart smaller wheels and gokart will have less weight gokart will go but with smaller speed. For 8:1 is too big, because there will be little top speed. I think original will be ok whatever i will use smaller wheels
Sry if you dont understand me :)
Kaptain Krunch
Pro Junk Collector
vermont
I think people didnt understand that this was an engine from a moped, and had a transmission, i think most people were thinking chainsaw or weed wacker engine. Anyways, although it probably would move a little with stock gearing, that engine just doesnt have enough power for a go kart of this size.
Kaptain Krunch
Pro Junk Collector
vermont
I highly doubt that, but even if it is you have 4 tires instead of 2, and that is a very small and weak engine to start with. Try it if you want but that engine will not be what u want. A motorcycle engine around 200cc+ would be a better fit.
