My first build
Paden87
Navarre, florida
So this is going to be my build. I just now bought a frame and most of you have seen the motor I have too. It's coming together slowly but I'm low in money so it will be a slow process.
n3480h
NW Iowa
That'll clean up nicely. It's amazing what a little elbow grease and paint will do for these old karts. Congrats on your acquisition.
"Streaker" eh? Does that mean you have to drive it nekkid?:eek:
Poboy kartman
Senior Moments Member
White Settlement Texas
Hang in there. ...someone with more knowledge and less smarty pants than this guy↑....will come along.......
(And you guys thought I was a problem. .......)....:lolgoku:
Paden87
Navarre, florida
So I took the cover off the motor so I could see the gearing and I noticed the governor arm was broke off and a piece of in was laying I get the oil sensor. So I just took all of the governor out
firemanjim
Just kartin' around....
Houston Texas
Cut off that arm and pull it out. Tap the hole so you put a nipple, if you are gonna run a pump. If not, screw a self tapping screw into the hole, for future use.....
firemanjim
Houston Texas
No need to re jet. We use a fuel pump when gravity no longer feeds the carb. The tank has to be an 1" or so above the carb inlet or fuel will not flow.
davidbooth1991
Nottingham UK
I don't know if this is applicable..( apologies in advance if its not.)...
On rc. Cars they have a hose leading from the exhaust into the top of the fuel tank..this puts pressure in the tank and forces the fuel through the lines..
firemanjim
Houston Texas
:lolgoku:
No, like this..... GRRRRRRRR my tablet is as fast as molasses......
You would use a pulse pump. The one you have would most likely be too much pressure..... I'm trying to post a pic.....
firemanjim
Houston Texas
That one you have puts out like 3-7 psi IIRC. You would have to use a pressure regulator and drop it to like... NO pounds...... Just a trickle.....
