My engine shaft conversion
NateIngram1
Middleburg, FL
I was stuck on what to do because i had a 2hp old briggs engine on my go kart, then i bought a 3.5hp briggs and the crankshaft was a 3/4 but the 2hp was a 5/8. so i looked and looked for what i could do do the crank shaft to fit my clutch for my other motor and nothing. so i thought why not just switch the crankshafts? i didnt see why not so i did it but i found you also have to switch the piston arms, but besides that it works great no problems at all!. the motor in the picture is the new 3.5 with the 5/8 crank shaft.
Nodroz
Belgium (Europe)
Lol, so you took a crankshaft off a 2h engine and put it in a 3.5hp engine? Is that even possible? :p
Why did you double post this topic?
r_chez_08
Should be in the shop...
Cornwall, UK
Nice :thumbsup:
You may find the connecting rod gives out if you give it too much stick, as the 2hp one was probably smaller.
I am surprised the 2hp and 3.5hp had the same stroke and crankshaft length.
Nodroz
Belgium (Europe)
Nice :thumbsup:
Same. The only difference will be the cc then? Nothing else? Weird though.
:iagree: If the bore is the same, logically, the stroke must be different. I'm willing to bet that, if you take your head off & check, the piston will not reach the top of the bore by a long shot.
You'll probably find that the 3.5hp crank has a longer "throw" on it meaning the conrod will be shorter
r_chez_08
Cornwall, UK
However, there may be just a difference in bore to keep the cost of production down. There also may be a more restrictive carb, and smaller valves.
A different case, but similar situation (except with stroke) is the Honda gx160/200. The gx200 has the same bore but more stroke.
Pretty sure the gx120 is a bored gx110 too.
NateIngram1
Middleburg, FL
I posted it twice because i didnt know where i should post it. and yes it is possible because i did it and it does work perfectly fine
NateIngram1
Middleburg, FL
The 2hp was an older model and the 3.5hp was sortof newer and the piston arm in the 2hp was the same length but it actually seemed like it was more heavy duty...
To put it into perspective, let's talk about Chev small block V8s for a sec:
The difference between a 327 & a 350 is 0.23" of stroke, that's less than a 1/4"
The difference between a 327 & a 307 is 0.125" of bore diameter, that's 1/8".
You more than likely won't be able to see the difference between a 2hp conrod & a 3.5hp conrod based on a visual inspection alone, some measuriing will be required.
Now, for all I know you may both be right; changing a carby, exhaust & a cam can quickly turn a 5hp engine into an 8hp engine &, as things like this are refined as time goes by, over 20 years, a 2hp may well have become a 3.5hp but, I doubt it. It will increase somewhat, but not by 75%
I recently tore apart two Tecs at the same time, a 4hp and a 6hp, to swap some parts around. The differences were quite minimal. While I don't remember the specifics of what I found, I believe there was a difference in bore of 1/8", possibly less. I had to mic it to be sure. The volume of the combustion chamber was the same, the stroke was the same, as were the ports and valves.
Engine manufacturers do stuff like this all the time. It does not take much to make a small difference in horsepower, and why spend money on tooling if you don't have to? From a manufacturing perspective, there's little difference. In my case, the same block casting can be used, and a different cutting head on the boring machine. Then, all they need is a different piston and rings. From there, everything else is existing parts...
In the same example, the one other difference in my two engines was the PTO diameter- 5/8" and 3/4". Again, just a slight difference in final machining.
Here's where it gets really funny: The manufacturer would likely have charged more for the higher hp engine- yet from the cost perspective, they would have worked out to the same...
r97
Measure twice cut once
Massachusetts, USA
If you give us the model numbers of the 2hp and the 3.5hp engines I bet we can search for the manuals and compare the bore & stroke specs for each engine.
r_chez_08
Cornwall, UK
Makes sense. I often think of that- You usually pay around double for double the hp with these engines. However the design cost is probably very similar, as for the machining cost (probably a little more, but once jigs etc are made this is marginal) therefore the main difference is material cost, which may be double, but that is still a very small proportion of the final cost. The manufacturers must make a much higher margin from these motors!
@ fabroman
i didnt say that the 2hp has 3.5hp now. i said i took the crankshaft out of the 2 and put it in the 3.5.
Neither did I, I was referring to this statment:
.. by saying:
Case in point:
327
Production: 1962–1969
Displacement: 327 cu in (5.4 L)
Power: 235 hp (175 kW)-375 hp (280 kW)
Bore and Stroke: 4.000 × 3.25 in (101.6 × 82.5 mm)
In the space of 7 years, the power output jumped by somewhere around 40% by refining alone
Source:http://en.wikipedia.org/wiki/Chevrolet_small-block_engine
