My electric kart project
Joe's kart
Ok so I already have a motor, battery, axle, two wheels w/ tires and a brake. I plan on buying a couple of bearings for my 1" live axle in the near future. Although, a couple of problems I've run in to are:
1. My motor has a #25 chain sprocket, and I can't seem to find anywhere a #25 sprocket for a 1" live axle or even #25 sprockets that would work on a sprocket hub. Everything seems to be #35 and up.
2. I have a motor that runs when I stick both wires into an outlet type thing on the battery but, I was wondering how I could string a throttle in between the battery and motor. Would I need a throttle and controller or ... .
Sry I'm new to everything. If anybody has any suggestions or links I'd really appreciate it. Thanks.
P.S. I have a 36v 750watt motor and a 36v battery.
Chuechco
Germany
Hi Joe,
I cannot answer question number one.
But take a look at this website: http://www.evworks.com.au/tech/
The electronic part of an electric vehicle consists of batteries, a controller and a motor at minimum. The throttle is a potentiometer that you hook up to the controller.
snowman86
nc
You can use a use a controller from a electric golfcart, as long as it is dc powered
