supermanotorious
Winchmaster 5000
So the voltage regulator went bad on my 2003 FXDX which I discovered by the battery smoking profusely under my seat in a McDonalds drive through. I tested the system and it was seeing roughly 19V+. I put a new voltage regulator on it and it was good again. However a few short weeks later it was running rough, then died for good.
Now, I had to replace the ignition module in October cause the bike was running rough and that was the culprit. In the couple days before it died recently, I noticed the rough running was similar to that back in October.
So, could I have fried the ignition module? I get absolutely nothing when I turn on ignition, with a good battery. Could I have damaged another computer like TSM? What are your thoughts?
---------- Post added at 10:16 AM ---------- Previous post was at 10:00 AM ----------
Oh, and the day it died- I was thinking maybe the TSM was bad due to high voltage so I researched how to bypass it. Found several things that said jump pins 9 and 12 so I tried it, it was at that moment the bike died,
