What do you mean with sleeve?
You take a piece of tubing smaller than your frame and slide it into both sides of the frame and weld.
Have a look here to see what I mean
http://www.diygokarts.com/vb/showpost.php?p=200160&postcount=25
Oh, thanks a lot! My plan was to strenghten the weld with 3mm steel plate on both sides. Would this be strong enough?
Sleave it if you can, will look nicer.![]()
welding plate on both sides will probably be the way to go.
Yeah, that'll look pretty![]()
Right on! This engine will wake things up! Will the oufput sprocket be in line with the swingarm pivots, or are you using a spring-loaded chain tensioner?
On the pictures you can see the frame is indeed tilted a bit. This is because of the heavy weight of the engine on the right side... I'm not sure how I will fix this. I'll try changing the front spring to be a little bit stiffer. Hope that will work!
