My Dirt Devil build
sexyvicta
my friends grandfather was killed by an exploding angle grinder disk. After i heard that story i've never used a grinder without a guard fitted lol
edit: the funny/stupid thing about that story is that my friend still uses his angle grinder with over sized cutting disks fitted which he has removed the guard in order to fit.
fowler
Bullsbrook West Aus
ya dont use a grinder without the guard
if u dont beileve/ dont care about the death myth (this true iv seen plenty of exloding discs)
then it is alot cleaner as the splarks only go one way and they dont come toward u so u dont get metal imprinted into u and your cloths
also if u want i can explain what happens if a peice gets in your eye hint, it involes a micro drill, not kidding
canaanp
Bushings?
Does anyone know where I can get the bushings I need for this build? The ones for the swing arm are 38mm OD and 20mm ID. The ones for the A-arms are 25mm OD and 16mm ID. I can't find a source for anything close...
