crazykart
Crazy member
So The axle I was going to use is an 18"x1" live axle with a 1/4" keyway and 1.5" threaded ends, which would have worked perfectly. So I went to double check my rim before ordering it today... 3/4" with a 3/16" keyway... that won't do.
Since I jumped the gun on buying the rims/tires (craigslist deal, dozen tires/rims for $40... sadly most of the tires were shot except the one I needed for the back, figured the rims alone would be worth it.) now I'm stuck with that rim and tire.
So I've decided to try and find a 3/4" axle with a 3/16" keyway at least 18" long with threaded ends...ya that is turning out to be impossible.
In all of your infinite wisdom I ask: does anyone know anywhere that I can get a 3/4" axle with a 3/6" keyway and threaded ends at least 18" long, max 24" long (or even a jack shaft) for a decent price? Or am I going to be stuck trying to find an 8" rim that will hold a 22x11.00 tire that also has a 1" bore with 1/4" keyway?
Gahhhhhhh!
I've been searching all day and it looks like I either pay $30 for a non threaded jackshaft thats 3/4" and then buy a die and thread it, or shell out around $50 for a new rim (only one I've found that will fit the tire and has a 1" bore and 1/4" keyway.)
Suggestions? Thoughts? Anyone want to kick me while I'm down and tell me I'm a dumb
(don't worry, I've been calling myself it since I measured the bore on the rim...I was so sure it was 1" bore when I glanced at it when I bought it, live and learn I guess)
Gahhhhhhh!
I've been searching all day and it looks like I either pay $30 for a non threaded jackshaft thats 3/4" and then buy a die and thread it, or shell out around $50 for a new rim (only one I've found that will fit the tire and has a 1" bore and 1/4" keyway.)Suggestions? Thoughts? Anyone want to kick me while I'm down and tell me I'm a dumb
