shuakarter
- Messages
- 2
- Reaction score
- 0
We have installed a centrifical clutch with sprocket on a go kart and have a 60 tooth sprocket on the axle and a 17 tooth sprocket on the clutch. It is burning bad on take off. Any suggestions
Over 4½ decades of experience has taught me something.and yes the problem is an overloaded clutch russ.
Can you give us some pictures?
Is this 1/2" pitch or 3/8" pitch?
What size tires are you running?
Just by reading this if I were a betting man I'd take a wild guess you have a Yerf-Dog kart which had a 6.5hp Tecumseh stock which had a 3/4" stock. You didn't think it was fast enough so you put a larger engine 8-13 hp on the kart which resulted in a 1" bore shaft so you could no longer use the 3/4" clutches. Since Comet is out of business you went to buy a 1" centrifugal clutch because you saw the prices on the large torque converters and were turned off, sadly Comet was also the company who made the only 1" bore centrifugal clutch which was also stepped down to 10t, all the other companies Hillard, and Noram who make 1" centrifugal clutches run the shaft of the motor through the whole clutch.This all means you're forced to have a huge tooth count throwing the gear ratio even more out of whack than your 18-20" tall rear tires happen to do. This may be a lot to swallow but I've heard this story before, if I'm wrong at least you had fun laughing at my jumping to conclusions.
Yowza , that's a he//uva mouthful to say "dude, you're geared too high."
I majored in English. But ah reckon ah kin dumb it down a bit iffin' ah have tah, ah s'pose.
