I just tested my Echo gas blower (rated at 390 CFM / 135 MPH). It developed 15-16 inches H2O (0.54-0.58 PSI) at compressor stall (my hand was blocking the end of the tube).
Now my math may be a little off, but going from -0.5 psi at the valve to +0.5 psi is a difference of 1 psi which works out to about 7% when you factor in atmospheric pressure.
Assuming flow rate is linear with pressure and my various other assumptions are pretty close... You should pick up 5-10% more power with proper tuning by using a leaf blower impeller geared up 3:1 (10,000-12,000 rpm max impeller speed).
IMO 10% would be worth the investment if it worked, but it may be a little silly if you haven't already done other basic mods like porting, carb, exhaust, and maybe a cam. It could be a safe and reliable 5-10% bump, or it could be a proof-of-concept type thing that leads to a 25 PSI of connecting rod breaking smog pump supercharger.
Finally, make sure you spin the impeller the right way! In your original post I noticed you using an impeller that compresses to the middle.. You have to spin it clockwise relative to the first picture to get it to do anything.
This Toro leaf blower impeller gets air from the outside edge and squishes the air to the middle.
This Turbo impeller grabs air from the middle and compresses it to the outside.
If you spin either of these types of wheels the wrong way they're going to do next to nothing.
