My buggy build
timmzzy
This is the buggy im making its gonna have dual gx 390 engines moded with an nr racing kit to improve the engines joint performance to about 40hp weighs about 250kgs and the engines are having a gear ratio of 1:6.5 with governor removed and max rpm at 5500 rpms and im using a belt to chain drive nd double manual clutch tensioner system 25 inch rear tires and 20inch tires up front . i tested my gear ratio weight horsepower and tire size for acceleration on the go kart guru site and it gives about 16ft/s^2 and top speed of about 64mph.
Use the go kart guru site i u also want to know this acceleration of your kart buggy and mini bikes@ go kart guru.com
Atlanta, GA
Dual engines? Brother, that sounds way too complicated. But hey, go for it and keep us updated.
