hello, i'm planning on building a kart to cruise around my backyard in
i dont plan to go more than about 10 mph, at least not in this first version which will use pullies and belts and a jackshaft and will rely on engine braking and a paddle brake on the rear wheel. the 10 hp tecumseh snow king engine i am using has a secondary counter rotating shaft that i'd like to try belting up to the jackshaft for reverse. i've got a pair of lawn tractor spindles and plan on making up a new front axle to widen out the track. all three wheels are the 8 inch rim 4 bolt pattern 4.80/4.00 trailer variety
my cardboard model is an inch to the foot and illustrates the plywood panel construction i plan to use, there will be 2x4 pieces at the quarter panels and forming a frame/tunnel down the center of the kart. all wooden parts will be glued and screwed together. the floor pan will be a single 4 x 8 x 3/4 inch plywood sheet and all metal parts will be through bolted to the wooden parts will extra large washers to prevent tear out or mounted on metal plates bolted to the frame, floor or body, inorder to distribute the loads and prevent crushing the wood parts..
i'll probably post scans of my pencil doodles and pictures of the motor and other bits i already have, but wont be cutting wood on this until february. i have yet to fully mock every thing up, whether i've got enough leg room, or exactly how i will get the motor, jackshaft and wheel to fit in the trunk
pat
pat
